I'm repairing a 512k with video issues for somebody, and when I disassembled the machine to get at the analog board, I discovered that the white plastic shield with the adjustment labels on it was held on with double-sided tape rather than the usual plastic push pins. Has anyone seen this before? Would it have likely came from the factory this way, or was this likely to be a later repair job? The machine has clearly been opened before since the floppy drive is an MF-D51W instead of the original OA-D34V type, and the logic board has some 1985 datecode ICs despite the machine having an '84 serial number. The holes where the pushpins would go are drilled in both the PCB and the plastic sheet, so the only explanations I can think of is that this was a hack done after somebody lost the pushpins, or maybe the factory was out of pins.
