I've got a Y adapter I use with one male and two female connectors, but I don't recall seeing male to male for SCSI offhand. What's your application?
Try widening your search: male to male telco connectors might be available. If not, you should be able to cobble one together with readily available parts.
HRMMM . . . make sure you're going by the gender of the contacts and not the shrouds around the connectors. The end with the wire bales is the female side, though the shroud makes it appear to be male as it inserts into the male connector's shroud. There are a lot of applications for female<->female SCSI gender changers, but I can't think of a single one for the male<->male sort.
