2X Mac IIcis and A bunch of other stuff.
OK So both IIcis now chime. I forgot my Mac-VGA Adapter in NYC, but I will be testing the one with the radius card at NYC and report back with the results. The power supply on the one without the radius card sometimes clunks at startup and the IIci does not boot. After a few tries it boots fine and stays alive. Not sure what this is . The other one's power supply is great.
The power supply issue is well-know, but here is an effective solution here quoted from the Macintosh IIci Homepage:
>RE the posting:<< Does anyone know if these 2 supplies are compatible, I need to replace the [iIc]x power supply and I may be able to get a [iI]ci supply. The main problem is that the computer does not turn on.>>
Before you buy a new power supply, try this: Get ahold of a cheap "power strip" with an on/off switch. Plug the IIcx into the power strip. When the IIcx is off, leave the power strip switch in the OFF position. When you're ready to boot up, reach down and flip the power strip on. Wait a few seconds, and press the keyboard power-on button. When it's time to shut down the computer, go through the normal shutdown procedure. After the IIcx "turns itself off", reach down and flip the power strip to OFF. Try this - you may be VERY pleasantly surprised with the results...
The theory is that the +5 V charge is still there briefly when you send current to the power supply. If you can start up the Mac quickly enough, you won't need the trickle charge while it's running.
Many people have asked me if I have a schematic for the power supply - I don't. Please send me one if you have it so I may post it on this site. Jan van Gennip did send some instructions (PDF) on how he repaired an Aztec power supply - thanks Jan.
I believe there are at least two makes of power supplies for the IIci, G.E. and Aztec. Mine is a G.E. and I haven't had a problem with it since I got it 5 years ago. Luckily, power supplies for the IIci are only around $15.
Yes Bunsen, I already warned him about that, as he did the same with the Radius video card. ;)
Not trying to make an example out of you here Mars478...I'm just posting this as a public service...I don't want anyone here zapping their Macs with ESD! :(
I've had that kind of stuff lying all over the place, including carpet, and have never lost a single thing from static electricity.
...not that I condone this kind of behavior, I'm just saying... :I
I can confirm there is absolutely very little wrong with placing bare electronics on a carpet. Indeed, I have tested motherboards, PSUs, hard drives, etc - yes, basically a whole computer in parts, on a carpet and all was perfectly safe. However, this is no reason to ignore common ESD precautions.
I realise they're probably fine; it still makes me twitch every time though.
The SIMM doublers are a rare and handy score.
