Greetings,
First off I am well aware of the issues with these monitors, overall, however it works, has a stable display currently, just is a bit dim, and especially after I installed the AppleVision control panel.
Before I installed Applevision extension, the display was quite bright (actually). Was a bit over the top but with the menus in the monitor I could tone it down enough for the mostly audio work I am doing.
What I am wondering is can I remove the saved calibration or settings from my Mac to revert back to before I installed the extension? In OS X it would be as simple as deleting a Plist file, however my muscle memory in using Res Edit isn't good enough. I have unchecked / uninstalled the Applevision extension, however the monitor is still locked into a dimmer mode than I would like.
I am well aware that 640x480 is max res without the extension, but the monitor is kind of far, and I am mostly doing Audio so am totally fine with the jumbo resolution
