I was wondering if anyone has seen this upgrade before. I assume so, its a rather professionally done board. And the soldering on the motherboard looks factory, best looking upgrade I have ever seen done to a 128k board!
But the problem is the cable! This one has a cable that connects to the mobo and to the board. Problem is the plug has less pins than the connectors for both. And its not keyed! So I can shift the connector far left or right. I don't want to assume that they way its hooked up is correct. And looking at the upgrade board, it can go either way. Far left and right pins have traces that seem to go somewhere. Then there is another cable that is rather long. It has a three pin connector with 2 in use. It seems to have some damage that I will have to fix. The length is odd, makes me think it was for a switch or a light or something. I see no other connectors on the board to where this would go.
Since the board plugs in on a sockets as well as the RAM, this upgrade looks very reversible. But what is up with the LED and resistor at R11? These to are so well soldered in that is looks practically factory done.
