68k Macintosh Liberation Army
It fit with clearance when I did it. How are you mounting it? Also note there are about four LC PSU designs and they have slightly different case designs.
Have you checked what the heatsinks are tied to? If they're grounded there is no issue anyway. Have you made sure to tie the PSU ground to the enclosure?
Boctor
Boctor
Mine is the Dyna Comp one, so I'm using the 3D printed bracket that sits inside, and the fit is extremely tight. The two heatsinks, according to the RPT-60 datasheet, should never have continuity, and that was actually how I blew one of the safety fuses when I first tried running it with the lid on. I tried covering the inside of the lid in electrical tape as a temporary test, but even the sides of it were able to short the smaller heatsink to ground, and almost blew something up.
Hum, the one in the photos is a Dyna Comp. Sounds like the 3d printed bracket is too thick.
Did you put all the insulation back in the case?
Boctor
Boctor
Yes, it's just the top pressing down on it. Maybe the 3D bracket is too thick? I got it from a local place, it's the STL from Retro Frog on Printables (site). I wonder if I'd have better luck tapping right into the bottom of the chassis like you did.
