I would give it a vinegar bath. Just the regular 5% from the grocery store, submerge and scrub with a toothbrush. Might need a dental pick or something to scrape any stubborn hard corrosion from component legs. Should need less than 10 minutes in the vinegar; probably closer to 5. I rinse thoroughly with distilled water afterward, then isopropanol to dry it out. You could even bake it to make sure it's fully dry.
