I haven't got mine handy, pretty sure I've got one though, but from what I recall from the gamba SE/30 lore:
__It's definitely a PDS Passthru Connector . . .
_______the passthru connector is the same length as the PDS connector for the MoBo
_______there's not room on the card for the NuBus Chipset, which uses a shorter EuroDIN connector anyway
_______because it's a PDS Riser format board, it has jumpers on it to change its Virtual Slot (?) address
_______ISTR, from the IIsi DevNotes, that some SE/30 cards cannot deal with the IIsi's faster I/O bus.
So,
if your problems are NOT PSU, PSU CAP, Board CAP issues or the same issues on the Card itself . . .
then check out the gamba site for info on the SE/30 multi-card hacks to make sure your problem with the slot isn't just an address conflict. If it is an I/O bus speed issue, you're scrod!
If
anyone has the docs for this card, or
ANY other IIsi expansion card, please scan them and post them! :approve:
< tangent mode >
AFAIK, the IIsi is basically a more capable, 5 MHz faster SE/30 in terms of its PDS centric I/O expansion feature set. The IIsi's roots would be more in line with the IIci's architecture and
Vampire Video subsystem with sound ports added for good measure. Whereas the SE/30 was basically a IIcx adapted to the SE format.
IMHO, the IIsi was intentionally hobbled in order to protect "High End Sales," as was/is the norm for low and middle market class Macs of most any era. This was achieved by the removal of the NuBus Chipset from the MoBo in order to limit it to either an Apple PDS Slot RA Adapter Card or an Apple RA NuBus Adapter Card. This can also be attributed to the IIsi's form factor and I/O structure and the limits these imposed upon placement of a NuBus Card by less skeptical 68k collectors.
A large number of developers wedged I/O expansion into this chink in the IIsi's I/O structure, developing all sorts of PDS Passthru RA Adapter Cards, making the IIsi an even more interesting subject for hacking to me than either the SE/30 or the Color Classic.
