Targa 2000 rom version 1.3 Nubus
max66
i tried so many combinations but wont work at all on a Q950 and 840AV
targa software 1.3, 2.2.1 , 3,1
system 7.5.1 , 7.6 , 7.6.1 , 8
quicktime 2.1 , 2.5 , 3.0
targa panel wont shown Video setup , and adobe premiere 4.2
wont enable the 'video input'
some veteran cutter can help me pls? very hard to find any documentation
about.
Unknown_K
There are 2 versions of the card, the original Truevision one with a VGA out and 2 or 3 round plugs for A/V and the AVID modified one with VGA out and 2 large rectangular plug for A/V. The truevision drivers will not recognize the AVID card at all (avid used a different daughter card and ROM).
The manual can be found online if you google.
Unknown_K
http://web.archive.org/web/20030516064654/www.truevision.com/support/TARGA/2000/NuBus/UserManuals/TARGAMacInstallGuide.pdf
Mentions OS 7.5.5 or later, Quicktime 2.5 or later, Most powermacs.
http://web.archive.org/web/20040701010747/www.truevision.com/support/HTMLPage.asp?HTMLPages_ID=28
Recommended Macintosh System
Apple Quadra 650, 660(AV), 700, 800, 840AV, 900, 950
24 MB RAM or greater (32 MB recommended)
ATTO Silicon Express IV
One or more AV-rated fast/wide hard drives
Apple System 7.5.1 (Later versions may work but have not been tested).
QuickTime 2.1
Apple Power Macintosh 7100/80 and 8100
Apple System 7.6.1
QuickTime 2.5
max66
i have 2 cards from truevision , one is single board how you described , 1 vga and 2 rounded connectors (input and output) , the oter one is 2 cards
separated phisically but interconeccted by flat cable ..look like SCA80
both have rom 1.3 , and both have same problems , i was thinking bad rom version flashed.
Unknown_K
The 2000 is just one card (2 layers), the AVID cards tended to have a cable that conected them to the AVID compression cards.
Have a picture of the cards?
Unknown_K
Never seen the double card setup before, interesting. The section it attaches to is where the normal compression board would be.
Where did you get that 2 card set? Anything written on them?
I know that the PCI cards had a ROM update for use with the later 720x468 NTSC intead of 640x480. I wonder if somebody used that ROM?
max66
fondamentally are the same card , but one have separate composite input/output , i guess the sandwich one is newer version maybe for to save 1 nubus slot , both cards have printed on it truevision everywhere and at boot time shown
'TRUEVISION' 1,3 ROM splashscreen. i have buy lot of old nubus cpu and pulled out from. since the 1.3 room is very old , i think the first version maybe the ex owners flashed with old rom then making them garbage.
