Simple mounting solution for SE/30 speaker
Zitruskeks
I had to remove the speaker from the faceplate of my SE/30 and was looking for a simple, non-permanent, adhesive-free way to reattach the speaker.
I designed a super simple washer that sits firmly on the speaker cone and allows the metal chassis to also hold the speaker in place.
If you want to print your own:
ymk
Nice work. Looks like it sits on the metal frame rather than the paper cone.
If it sat on the cone, the speaker wouldn't work all that well.
Probably a good print for TPU filament.
olePigeon
Nice. Simple and effective. How thick is it? Could also cut one out of foam using a laser cutter.
Zitruskeks
Its 3,50 mm in Thickness, so its sits snug, but not overly tight using the original rubber pad between the speaker and the front.
Foam would be rather stiff to be ableto bridge the gap between the mac chassis touching it on the rear and the point where it sits on the frame of the speaker.
