jeremywork
I took a longer look at this picture and have a couple more observations. My 840av is out for the count so I can't directly compare, but that internal bus reading looks too low- either the SCSI2SD will have no benefit in the SEIV, or there's some other bottleneck here. I get over 3MB/s on a period 230MB hard drive on a Quadra 700, and a bit over 4MB/s for a later 1.2GB drive on a 950. The 840av having a faster bus should put it even closer to the 5MB/s Synchronous limit of its SCSI controller.SCSI2SDv6 on internal 840av bus (bottom line)
vs
IBM 17gb 10k SCSI (Hitachi) on SEIV bus (top line)
FYI the SCSI2SDv6 is using a slower 6.2.5 firmware, as newer firmware cause corruption on write at the moment (is being fixed)
On the other hand, your SEIV is much faster than I can achieve in my 950. I can only get around 8MB/s on a 15k SCA>68pin, but that's almost all due to lack of full Nubus 90 support, which the 840av has.
