SCSI HD only works with external terminator attached
robin-fo
Hello everyone
I have this 1050MB IBM 50 pin SCSI drive which came out of a Powermac 7500 and worked somewhat reliable on its internal SCSI bus. However, when I use the drive inside a Quadra 700 or Performa 475, it only spins up (!) if an external Terminator or another device with termination is attached.
The jumper for termination is set, so I have no idea where the issue is.
Any thoughts?
ymk
It appears to be missing the resistor packs (or equivalent) at U6 and U7.
Only some logic boards provide automatic termination and I don't think the 475 is one of them.
If you don't want an external terminator hanging off the rear of the machine, look for a 50 pin terminator.
ymk
It may be useless. I could see Apple shaving off some pennies by ordering a large run of drives like this.
