andreadandrea
Hi everybody,
I have an issue with my Quadra 700 + MacOs 8.1: my second HD automounts and works fine, but doesn't boot.
I attached a second HD (MAB3045SC, 4.5GB, scsi-3, 68 pin) to the scsi bus with an adapter cable, assigning id 2 to it.
I formatted and partitioned it with FWB HDT 1.8, marking it as automount and bootable.
The HD works fine and automounts, but no way boots.
I chose it as startup HD by the control panel, but doesn't boot (the first HD will boot instead).
I left it alone in the scsi bus (with id 2), but doesn't boot (? mac icon).
I tried some startup key sequences to change the startup device, but all the same.
What could you suggest me to do?
I'll appreciate also emails to andreadandrea at tele2 dot it
Kind regards,
Andrea
Kind regards,
Andrea
