corbinq27
When I inherited my Grandmother's Macintosh SE, it came with a little surprise: a MicroMac Accelerator card. It goes on the PDS and bumps the machine to a 68030 @ 25 MHz with support for at least 16MB of RAM. Some of you may have seen it when I was at VCF Midwest 19 last month.
There's an issue I've had with the machine as of late: when I boot it I get an EYOERR on it. If I leave the machine plugged in for a few minutes it resolves itself. That seems like a capacitor problem and sure enough there was plenty of juicy oxidation and cap juice on the card.
I finished recapping it tonight. The good news is the card is working just fine. The bad news is it still does that EOYERR thing. I'm guessing I'll need to look at the analog board next but feel free to chime in with your opinions.
Also: I'm pretty sure that before I recapped it when I played the Oregon Trail 1.0 the game would freeze. I did not seem to run into this issue tonight.
I've installed the Connectix extension / control panel piece that lets the machine actually see the extra RAM. I was told by someone at VCF MW 19 that there's some fun stuff you can do with a RAM disk with this card too that I'll have to try sometime.
Here's some pics. Not my best solder work but alas.
Also: I have a hunch it's using the RAM on the main motherboard and not the RAM on the card. Perhaps the RAM on the card is only for the RAM disk. I'll have to confirm that at some point too.
