Radius Pivot Color Adjustment
DontGetHit
I just got a Radius Pivot Precision Color 0356 and the picture is very pink. Is there anyway to adjust the color? I can't seem to find any sort of menu. I don't have the card so I do not know if that is required.
olePigeon
For color, unfortunately, I think that might require taking the case off and adjusting the RGB potentiometers. It could also be capacitors that need to be replaced that are messing up the color, or a cracked solder joint. Basically, it could be almost anything at this point. You'll need to track down disassembly instructions somehow.
