chikorita157
I finally managed to move the resistors (or rather, replace them since I lost the two when I tried to remove them and move them), and it seems to work in Mac OS X with a reduced ROM. However, it only shows a blue screen when booted with Mac OS 9.
The question is, do you need a full size ROM flashed to make it work under Mac OS 9. Also, can you flash a blank ROM chip directly with Graphicellerator or do you need a ROM flasher tool,
The card I'm using is a Sapphire Radeon 9250 256 MB PCI, which recognizes itself as a 128 MB one.
