I have a Macintosh SE/30 and recently got a The Old Net RS232 modem. While it works wonderfully, I noticed that baud settings don't seem to change the speed that much (eg. I get about the same max speed from ftp download from a local raspberry pi from 9600 baud and 57600 baud.
I checked out my config in TattleTech and the Modem Port is listed as having "Max Baud = 57,600" but "Current Baud = 9,600". I've changed my baud settings on ZTerm and the modem and they can communicate well, so I'm wondering how much I should trust what TattleTech is telling me.
- Is the Current Baud reported by TattleTech something I should trust, or would I go with whatever I set in my terminal / PPP apps + the modem itself?
- If it is important. Is there a way to change that value?
- Is the modem port the right port? The printer port is the same connection but that doesn't seem to detect it, and I have an adapter to connect to the DB25 SCSI port but haven't tried that as the physical setup in my desk makes it a bit odd and other than the baud issue the serial port was doing OK
Any help much appreciated!
