Question about Performa 630CD & DOS Compatibilty
Richard
Banned
Can a normal Performa 630CD be turned into a DOS Compatible Performa 630CD with a card, or did those models have something special about their motherboard that the normal 630CD does not? If this is possible, what card would I need? Are they common?
Charlieman
No. A special logic board is required. They are not common where I live (UK) but elsewhere may be different.
LCGuy
LC Doctor/Hot Rodder
The easiest way is to, as Charlieman said, to just buy a full, complete LC630 DOS board.
The logic board used in the LC630 DOS is not "special", but rather, updated. It uses the exact same board as the LC580, which has two SIMM slots, and the Apple Internal Video Connector, which is used to provide external video out on the 580 (with a very hard to find adaptor cable), or to send video from the LC630 DOS board to the display on the LC630 DOS.
Either way, you'll still find it a lot easier to simply track down a full LC630 DOS board rather than just the bare card, not to mention that to use the card, as well as needing the card, you'll need the video adaptor, the sound card, and the gameport/LC PDS adaptor, all of which you'll only be able to get from an LC630 DOS Compatible.
