Programmer's Switch on Mac Portable not working
NJRoadfan
Any item why?
I installed MacsBug 6.5.3 to test it out. The debugger installs on boot, but pressing the Programmer's Switch does nothing.
nvdeynde
These switches often go bad. Replace it: anyone from another Mac Portable or Compact Mac will do as they are identical.
I don't know if new switches like these are still for sale.
RickNel
I'd first be checking whether the physical contact-switch is the problem. They typically contain a tiny spring-metal dome that can get deformed or broken in some circumstances, or the action can be blocked by a speck of dirt of some kind. First check the on-off operation with the continuity tester on your multimeter, and if it fails look for a mechanical reason. If it needs to be replaced, the actual switch mechanism is quite generic, but it is also possible to wire in a non-standard contact switch if you have to.
IIRC there is also an isolation capacitor near that switch, which I would look at next if the switch appears to operate correctly.
Deeper than that... :-/
Rick
NJRoadfan
The isolation capacitor was replaced along with the rest of the caps. The reset switch works fine so I found it odd that the programmer's switch didn't. I'll have to check it again to see if its closing.
nvdeynde
Are the 2x small SMD capacitors near the switches soldered well: test them and check for lifted traces as well. Otherwise check the circuit from the switch to the next component for broken traces.
Anyway it's not really a big deal that the programmer switch doesn't work as you don't need them when the logic board has been recapped.
I never had to press the reset/interrupt switches again after recapping my Mac portables while before it was always a pain and guess after how many times it would start...
NJRoadfan
The reset switch works fine. Testing the programmer's switch isolation cap, I get continuity from the negative terminal to one of the switch terminals. The positive terminal gets continuity to a pin on the "MISC GLU" chip as expected. When power is completely removed from the machine, I have to power cycle it for a good minute to reset the PMU and clear the instant sad mac despite being recapped.
nvdeynde
How do you power cycle it ? If you have a working battery this shouldn't be necessary as when you remove all power, the capacitors drain quickly and then the PMU is automatically reset in a matter of seconds. You have a rebuild battery I assume ?
What sad mac code do you get ?
I use my Mac Portables regularly but never leave the main battery installed. However they always power on immediately after inserting the battery and pressing the keyboard.
I have seen Mac Portables from fellow collectors that used the Mac Portable without rebuild battery on a heavy DC PSU and got the logic board damaged this way ( PMU errors, unstable, often not willing to power on,... ).
We also never know what previous owners did with the computers before we got them...
NJRoadfan
I'm using a rebuilt battery and the stock 1.5A power supply. Errors are usually 0000 13xx or 0000 17xx, neither of which actually come up as valid codes. Once the PMU finally resets, I don't have any problems until power is removed again by taking out the battery.
