I was watching that one too. Ended at $260.50 when all was said and done. Thats about what it would cost for a Quicksilver G4.Ebay Item number: 200304661225
$200 and not even over yet, what gives?
Well, it wasn't exactly a "normal" 9600. It had the 350MHz Mach V in it, so its a little more rare than your average 200MHz beige Mac. I do agree that $260 is much more than its worth.260$ may be worth for to pay a 9700 prototype but not for a normal 9600.
...except hold large numbers of PCI cardsnewer setups are cheap and seem to do much more
[I have no clue.
I meant newer AVID setups, and they don't need alot of PCI cards... and the second quote, well just wait untill I find one of your posts and take it out on context...except hold large numbers of PCI cardsnewer setups are cheap and seem to do much more
[I have no clue.)] ]'>
He has everything. He just needed a spare for the system. Also, Avid is pretty choosy when it comes to Processor upgrade cards. Having the 350 604e is a good thing.Sure if you have all the AVID cards, media drives, software, cables, breakout boxes, and the elusive dongles. Odd to have all that and not the 9500 or 9600 they were installed in.
