PPC G4 MDD
Arielle
New member
I purchased my first Mac from a friend ages ago for $150 and just realised that it's a single 1.25Ghz CPU model. I'd kind of like to upgrade it to a dual as making music on it isn't the easiest because of software demands that the CPU can't really handle. I also have a G5 7,3 with 4 GB ram.
Do you run Mac OS 9 or OS X on it when using the music software?
volvo242gt
If the latter, I would be tempted to use the G5 for the music. Especially with the fact that a stock MDD is not the quietest machine when running, especially when there are two processors instead of one.
s_pupp
You’re not kidding. WhenI bought my dual 1.25 2003 MDD G4 in 2003, I was shocked at how loud it was in OSX Panther. Then I booted into OS9, and listened in horror as my expensive new computer produced a sound that resembled my vacuum cleaner, both in tone and in loudness.
volvo242gt
Exactly. Did a good impersonation of a shop vac trying to lift a brick. I wound up downgrading mine from a dual 1 GHz processor card to a single. Became tolerable.
