PowerMac G5 7,3 MacOS 10.4 nstall disk
BlackScorpion
New member
I just got my hands on a PowerMac G5 7,3, it has MacOS 10.5 on it, i'm looking for the MacOS 10.4 for this computer, I've tried all over to get a working copy, but been unable to get it going.  I need to run classic MacOS 9 on this system, for older software i want to run on it.  Any help would be greatly appreciated.
EvieSigma
Young ThinkPad Apprentice
Is a 7,3 a PCI-X or PCIe G5? Any PCI-X G5 can use Tiger 10.4.0 install disks but a PCIe might require 10.4.2 or higher. In that case, there's a DMG of 10.4.6 out there you can use for installing Tiger.
BlackScorpion
New member
I'm not sure which one it is,  The DMG you mentions does not work on it.  I run into kernal panics wit the DMG and the retail disk.
EvieSigma
Hmm, that's very strange. I installed 10.4 via a 4CD set on mine just fine and installed 10.4.6 on an iBook G4 that demanded 10.4.2 or above from the 10.4.6 DMG.
Cory5412
Daring Pioneer of the Future
Staff member
I'll look again when I finish the downloads, I browsed Mac Garden for the 2005/PCIe (which if I searched correctly should be what the 7,3 is) install disks and couldn't find them.
10.5 would be a slam dunk on that machine, but wouldn't run classic.
If you can swap that machine, or find something else to run whatever you need in Classic, that's what I'd do -- 10.5 on that G5 will run well and will make much better use of that hardware than any Classic app will.
This is still, I realize, not what you asked, but any software that runs well on a G4 on OS 9 will probably run better as a newer version on a G5, especially those last-gen ones, especially-2 if it happens to be a Quad.
LaPorta
Will retail 10.4 work on it? I was pretty sure that’s what it came with.
Cory5412
Staff member
I mis-Googled before:
The 7,3 is an AGP model from June 2004 originally shipping with 10.3.4, so both the 10.4.0 and 10.4.6 retail discs should work.
