I have a Mac power CD it doesn’t have its powerbase so it’s a paperweight.I have 10v transformers, and scsy cords, do any of you know which pins on the scsy port need to be powered to get this thing to run?
If so I could make it into a stand-alone CD player (an improvement over a paperweight).
:lol:
That is
NOT a SCSI Port! That's a generic DB-25 Connector! Apple was the only Dip$h . . . erm . . . idiotic . . . organization . . . that foisted this
sub-standard connector on their users. It was used just to
save room on the back of the 512ke, instead of using the Industry Standard Centronics 50 Connector that has been in use since the Mini-Computer era! Other companies followed suit, but it was a stupid notion to begin with and it's STILL a . . .
mode>
That said, unless they torqued
everything out of spec (not at all uncommon within the infinite loop) they must have uncoupled some of what are "supposed to be" alternating ground/signal lines. I thought they tied all twenty-five ground lines together at the DB-25 end of their bobbed "SCSI Cable" instead of having discrete connections at both ends of the ground lines per the SCSI Spec. They may or may not have done so, but the DB-25 <-> DB-25 connector linking the two halves of the PowerCD may be something entirely different!
Check the standard pinout of Apple's DB-25 "SCSI" connector against the pinout for the Standard Centronics 50 SCSI Connector at the "peripheral" end. Hook up the DB-25 end to the PowerCD and buzz the connections on the Centronics 50 end with a continuity tester. You're looking for a few "ground lines" that aren't connected to the Ground shells of either the DB-25 or the Centronics 50. If they all connect to ground, you'll have to "roll your own cable."
But if you find one, or several, "ground lines" at the Centronics 50 end that
aren't connected to ground, but to each other, dollars to donuts, you've found your "power lines." They're actually almost as good as real ground lines for shielding the address/signal lines against crosstalk.
One way or the other, you're going to have to make some kind of conversion that'll let you feed power to the PowerCD while passing through the SCSI Data and Signal lines.
BTW, 10 volts doesn't sound right, are you SURE about that?
Happy hacking, comrade! :rambo:
