Powerbook G3 Pismo seemingly dead?
EvieSigma
Young ThinkPad Apprentice
I recently got a Pismo (with a 500MHz PPC7410 upgrade!) but it's...seemingly completely dead? Plugging in my 45W yo-yo adapter does absolutely nothing, neither does the key combination for a PRAM reset. Is something fried? Do I need a different power adapter?
greystash
The 500Mhz CPU is nice! They're quite hard to find now.
I'm pretty sure the power cards fail on the Pismo often. I had the same issue, no power or signs of life but after replacing the power card from another Pismo (working) it booted normally. It would be worth re-capping the machine as this is probably where the problem is coming from.
Trying another power adapter is a good place to start, otherwise either a new power card or re-capping might bring it back to life.
MacUp72
I had a Pismo with a standard G3 400 Mhz daugtherboard with booting problems, I carefully removed the board and inspected it..two little pins were ever so slightly crooked, I carefully bent it back..it never booted again..temper temper
I hate those connector boards, the latest 500 mhz models had better ones
EvieSigma
The only one of those I found on eBay is $40 shipped so I hope I don't need one...I can try swapping the other power board from my working Lombard into the Pismo, though.
