oliviaiacovou
I've got this PB G4, it boots just fine most times and tends to get to the desktop, seemingly fine, however after a few minutes it kernel panics, then sometimes shows an openfirmware error, displaying a memory issue. Apple Hardware Test reported no faults. I've tried without an external dimm to make sure it isn't that, and it still has the same problem. Is it possible to simply take the memory chips off the board and only use the dimm?
And also, is there anything else I haven't mentioned that I should try first?
