Potentiometer replacement for 12" RGB Display
cruff
You'll need to determine their physical size, footprint, value in ohms, if they are linear (probably) or logarithmic taper, and the power dissipation needed in watts. Reviewing the schematics would give you at least ohms and possibly the wattage. Measurement of the PCB will determine the physical characteristics.
