PLI SuperFloppy 2.8
Charlieman
I have just acquired one of these drives. It's a small SCSI box wrapped around an auto eject 2.8MB floppy drive that was sold early/mid 1990s for Macs and NeXT boxes. I have not found any info on how much the two versions differed -- I suspect it was down to the software bundle.
I've tried it with a PCI PowerMac running System 7.5.5 and Mac OS 8.1, plus a whole bunch of SCSI formatters. Alas, I don't have a real 2.8MB floppy so I'm trying it out with 1.4MB floppies (Mac formatted, known working). Basically I am not getting anywhere with generic formatters, so I'd appreciate any help locating the original software. SilverLining has a go at formatting a floppy disk (at 1.2MB) but nothing else even tries.
Any pointers or should I reserve it for the next time I wrestle with my NeXT?
Charlieman
The PLI utilities at Mac Driver Museum are for the earlier Syquest drives, alas.
I thought that I had broken my drive after cracking it open to take a few photos of the internals. I cracked it open again, ensured that everything was seated (the ROM is the only socketed DIP chip), twiddled about and it partially works again.
* The floppy mechanism is labelled Sony MP-F40W-1Y. It uses a 20 pin ribbon cable and has no supplementary power. It is an auto inject/eject drive. I have not compared physical size to a conventional 1.4MB mechanism.
* The physical ROM carries a paper label: "V1.4 PLI©NXT288".
* The board is silk screened "PLI Turbo Floppy".
* There is a square socketed chip next to the silk screen label that I cannot identify because the marks are so indistinct.
* Mac SCSI utilities identify the ROM as version 1.00. A couple of formatters have a go at formatting a 1.4MB floppy disk and the result is a 1.2MB not-especially-useful disk. I presume that the formatters are assuming block/sector/MFM parameters.
I have my own thoughts (about which I will be quiet initially) and welcome yours.
Dennis Nedry
Have you tried the Applied Engineering SCSI floppy drive driver at the Mac Driver Museum? Very unlikely to work but you never know.
protocol7
Did you try the PLI formatter? I know the link says the tools came with a Syquest drive, but there's a chance it might still work. It appears to be a fairly generic SCSI format tool.
I'm guessing the onboard ROM contains the driver? Maybe it only contains a NeXT driver (judging by it's label) in which case, a Mac driver may still be needed.
Charlieman
PLI Formatter: This is a rebadge of a third party formatter. It is very similar to a MicroNet formatter in its layout.
AE Drive Drivers: The Mac Driver Museum description is incorrect. The AE drives all used the floppy port to the best of my knowledge.
Onboard ROM: My bet is that it is just stores parameter and declaration data. Many SCSI utils can read it and a couple of formatters have now produced 1.2MB MFM floppies for me.
I think that the paper label is misleading and that the same ROM was used for Mac and NeXT versions of the drive. I really need the software for this one to understand it.
