cmosless
I needed to copy some applications over to my Macintosh Plus, and the only working Macintosh I have that should be able to do this is my Performa 6400/200. Although it has a dead PRAM battery, the machine works just fine, but I noticed some odd behavior with the floppy disk drive, and I can't quite figure out what's wrong.
The drive reads and writes to 1440k floppies perfectly. No issues, will format every time, respects the write-protect switch, and so on. However, when I tried using a 800k disk in the drive, initially it would recognize the disk, but fail to copy files to it or format it. This was the behavior it exhibited the first time I tried using 800k disks in the drive (after not powering it on for a few years). Now it simply will say the disk is write-protected, no matter what I do (including putting tape over the write protect switch). However, if I take a 1440k disk and cover the HD hole with tape (bad idea, I know), it works just fine as a 800k disk. Formats every time, reads/writes fine, and even will boot my Macintosh Plus.
The 800k disks I am using all function properly on my Macintosh Plus (both in the internal and external drives), and I have even tried different brands of disk with the same results. Does anyone know what the issue might be, and how to fix it?
Thanks.
Thanks.
