Nice little machine you got there.
I have always liked that style of case and someday will own one of those.
It's so... odd-looking, and cute. I named it Evil Calvin because the drive icon was Calvin's angry-looking face from Calvin and Hobbes. ;D
Do you think I'll see a considerable loss/gain in speed if I switch to 9?You can get Open Transport from http://www.info.apple.com/support/oldersoftwarelist.html which should do the trick (or put a more modern OS on there, 7 is not good for PPCs anyway as it's mainly 68k code - Mac OS 9.1 is the newest the machine can take and will have everything you need straight out of the box )
Nope, not at all a collectors item.alright then il spel it out
those rainbow stickers are both valuable and wanted
you just destroyed a collectors item
Usually that would make sense, but the only thing I could use from this machine is the motherboard. (if anything should ever actually happen to my good one)Keep it for spare parts.
Speaking of different PCI risers, was there ever a model with a single-slot riser?If the modem is really 56k and you have no desire to keep it, you might try selling it on eBay; internal 56k modems for pre-B&W G3 Macs are relatively rare. Somebody out there may be in need of a CS II 56k modem for their old box... I may have one of these at most in a beige G3, the rest are 28.8 or 33.6, though of course I don't use dialup anymore (except when I use my 540c as a fax machine).
As for the rest of it, I can't think of anything I'd do with it. I'd probably keep it for parts - you never know when you may need a spare drive, or power supply (if you can get it out of there, haha). The motherboard is also interchangeable with a number of models if fitted with a different rear plate and PCI riser (6360 and 5400-series), plus more if the power system is modified (6200/5200, maybe the 630).
That's alright. As long as it works. I could always make modifications to stabilize the card.They are interchangeable, but they won't mate up with the backplane correctly. The tray designs are different.
Peace,
Drew
The problem isn't stability, it's that it won't line up with the opening in the backplane.That's alright. As long as it works. I could always make modifications to stabilize the card.They are interchangeable, but they won't mate up with the backplane correctly. The tray designs are different.
Peace,
Drew
Does anyone have a pic of a single-slot riser?
I need to find out if it's actually shorter than a dual-slot card and by how much.
That's not a problem.The problem isn't stability, it's that it won't line up with the opening in the backplane.
