Performa 200
falen5
the high frequency sound ? ........I thought the same........as it is not right..........
I havnt opened it up yet...but looks like I will have to...........the drive is dieing..........and it was full of software.
any suggestions?...........it is either a particle trapped between the head and the platter of a mark on the platter. But even if I open it.....what can I do
feck...........chances are that allot of my drives will be the same.
I plan on taking down each machine in the next week or so and removing every drive.............all I can do is keep them in a room with a more stable temprature
falen5
my main machine - I7, 32 gig ram, GTX 460, 50meg brodband
paste does not work..period!!!...........just checked......is Bunsen the site admin?
will ask him to check it out
its been like this since I joined the forum
unity
Well it sounds like an OS issue more than a site issue, but I would not know why. You can certainly try asking Bunsen or Corey. I would think if other have the issue, they would have mentioned so.
falen5
just sent Bunsen a request to check my profile status.........try and resolve it
I use win7 64 bit ......and 32 from time to time...........I have no idea........I doubt its OS as I ghost my machine back to fresh install every few months
I can post pictures no problem , but only on the 'more reply options' as there is no 'attach' command on this reply box
uniserver
you can still run a wire from pin 22 of U4 to the negative pad of c4, removing the c4 cap.  and you will still get audio out of the speaker and headphone jack but at about 50 percent of previous volume all the way up.
with u1 being gone. the computer will still work but you really want to remove U4 and inspect the pads and traces.
good job!
falen5
unity - how do you paste a utube link..is it on the standard reply box?..right click and click paste?..........cause that will not work for me.
Do I appear online down below as a member.....all along I appeared as anonymous...............even though Im a member..........am I a member??? ....
ah..........Bunsen will sort it out hopefully
unity
^ Not sure how that appears above to you, but to me they appear just as yours do. Right in the box in the thread. All I did was copy the URL from the address bar, paste and click 'post".
360alaska
I can't see the videos either... was it, the holy ghost? :)
I tried turning adblock off and it didn't help...
falen5
unity - its the exact same.
unless I click 'show all content' I cant see your vid.
when I did...screen refreshed and up popped a vid of a clock
what the hell!"!!!!!!!
jhorvath911
Just wanted to say gee thanks for posting that performa tour cause I had to sit and watch all 23 minutes of it since it was there haha... On a side note when I'm using Internet explorer I have to click show all content to see videos but on my iPhone they just show up as they should.
falen5
thanks jhorvath911 ........... started to think I was going crazy there..you see 'Show all content' as well........its probally antivirus, or firewall crap so.....cheers man
Uniserver I just want to confirm this before I try it
pin 22 of u4 to negative of c4 and remove c4. Are you pretty sure this wont blow anything else up!!!!
do I have this right?
cheers uniserver
