PCI to PCMCIA/CardBus Adapters
Charlieman
I am looking for tips and links about using these in any PCI PowerMac. Ultimately, I'd like to try one in a Pippin (yes, I have the PCI adapter board, a selection of ROMs and RAM cards, external SCSI etc) to see how much further it might be stretched.
The sort of questions for which I seek answers include: Do adapters require a software driver, or do they function as seamless bridges? What are the OS requirements above System 7.5.2? Am I right to assume that if a Mac PCMCIA or CardBus driver exists, it will function with a card mounted in an adapter?
Please note that I am not asking anyone to do my homework and merely seek a few pointers.
PowerPup
Hm.. Well I do know that a PCMCIA extension does exist in the Mac OS. It's called something like "PowerBook PCMCIA extension" though I don't know which PowerBooks required it and whatnot.
My guess is a driver/extension of some kind would be required. But it doesn't hurt to try without any. ;) It probably won't work, but it won't hurt.
Charlieman
PowerPup is thinking along the right lines. PowerBooks based on PCI architecture must use a PCI to PCMCIA or CardBus bridge chipset. Therefore a driver for that chipset is part of the OS. So what bridges were used on PCI PowerBooks? Apologies for asking in the wrong forum.
PowerPup: My bet (without booting my PowerBook 5xx with the card reader that sometimes works with WiFi cards) is that the extension you mention extends the ability of NuBus architecture PBs.
Gorgonops
Moderator
Staff member
My completely ignorant reply would be that *if* the OS recognizes the bridge chipset as being the same/similar enough to one in a Cardbus-capable Powerbook (Which would be, what, the 3400 at minimum?) than it might well work, unless the Apple driver specifically looks for other Powerbook-specific attributes before loading it. Otherwise you're probably out of luck. (There are not very many makers of Cardbus bridges, I believe the one in the 3400/Kanga was made by Texas Instruments. If you're still looking for the adapter I'd probably try to match the bridge in a Powerbook as closely as possible.)
The only PCMCIA slot adapter I have any experience with is an ISA-to-PCMCIA (no Cardbus) model. Linux worked basically out of the box with that using the appropriate bridge chip driver, although I had to modify the modules config in Debian to load it. (It's not on the list of drivers which probe automatically.) With said bridge I can actually seamlessly join my 1997 vintage Dolch lunchbox to WPA1 encrypted networks via a WaveLan Silver card pulled from a dead gray AirPort. Yay! ;^b
Edit:
http://people.wallawalla.edu/~Rob.Frohne/Cardbus/Cardbus.html
The 3400 used a TI PCI 1130, apparently.
Charlieman
Cheers, MacJunky. I spotted those cards too but was discouraged by the Mac OS 9 requirement.
The PB 3400 is a good starting point. It will run System 7.6 onwards and supports PCI to PCMCIA/CardBus bridges. I was very discouraged by internet searches previously, but I am now more positive. If, off the top of your head, you know which chipsets were used for this purpose in PCI PowerBooks, please shout up.
(As I write, Gorgonops comes to the same conclusions.)
MacJunky
I know that this does not really help the System 7 part initially but perhaps we should be making a list of the chipsets used in all the PCI based PowerBooks just as a starting point then hunt down the desktop versions after that? That way we can cover Macs running 8 and 9 at the same time.
Lombard:
(TI) PCI1211PGE
WS/PDQ:
(TI) PCI1131PDV
