pci card
bluekatt
can anybody identify the name amnufacturer type name etc of this card ?
it sobviously a pc card
the seller said it was a amd k6 466 but i somehow doubt it
if the photo's are some what fuzzy here is whats on the board and chips them selfs
ATI mach 64 215ct22200 pd96137gd-401-lml
9548kc594
sis 85c496
under the heat sink apple computer inc © 1996 820-0728-b
fcc id bcgm4091
personally i think its an p1 card which is fine
what i want to know is what card is it exactly
where can i find its drivers ?
and wil it work in my quicksilver under mac os 9.2.2 ?
edit : crap photo's form my crap camera urgh
coius
PC Compatible Card. It allows you to run Dos on an older machine (under OS 8.5) and takes a DIMM slow specifically for the P1. Most likely a Pentium 166. It's the 7" version. I have the 12" version but nothing to connect it to. Anyways, You *MUST* use the same ram that goes in the machine (not like PC-66/100/133) as normal PC ram won't work. Google PC Compatibility card for mac.
Anyways, the Mach 64 was the video chip, the SiS is the sound chip
The white thing is a connector for systems that have internal ports for it (like the AIO machines).
The thing does NOT work with Beige G3s, nor does it work with any G4s. Sorry.
Like I said, google that, and you will get he PC Card tools for it, and the drivers.
It's good for machines like the 7200 or even a 9600 (better bet!)
max it out with 32MB (sometimes 64, it depends on the revision) and get that sucker running!!.
BTW, i couldn't tell by the pictures accurately, what is the length of the card? that will help me tell the CPU speed, i actually think the 7" topped at 90Mhz, and the 12" was the 166.
did you get any cables with it?
Oh, and to answer your question, no, it won't work w/ the G4
bluekatt
i knew what it was just not exactly what it is
im a metric user the card is 17 cm long
i take it the card is able to run windows 95 as well ?
it has ram installed already no idea what kind yet
so now the hunt is on for a pre G3 mac hopefully with a G3 card in it
i have the cable with the internal ports connectors
with some luck its a p1 166 and 32 mb ram
not too shabby for 20
Bunsen
Admin-Witchfinder-General
There was a PC card with a K6/466 on it, but it was made by Orange, not Apple.
bluekatt
seller said it was an orange micro instead i get the apple one
maybe il get rid off it
anybody interested ?
defor
You can make up something and come back to it late
Staff member
you happen to have the internal interconnect cable? if so, i'm interested.
bluekatt
you mean that little ribbon cable that goes in the white connector and ends in a small card with two prongs so to speak ?
Bunsen
I'd contact the seller and tell him he sent the wrong card. If he actually has an Orange Micro K-466 and simply sent you the wrong package, then you should get the right one. It's a much better card.
