OWC Legacy SSDs Incompatible with PowerBook G3 Wallstreet
JDW
I started this thread to serve as a warning to my fellow PowerBook G3 Wallstreet owners who may be contemplating an SSD. Reasons for adding an SSD are numerous, including elimination of noise and heat, power reduction, and greatly improved performance. Sadly, after spending dozens of hours debugging with OWC staff over the past 4 months, and after going through two RMAs, I cannot recommend the OWC Legacy SSDs for the PB G3 Wallstreet. I am posting this today because OWC refunded my money today, bring a close to my long and unsuccessful journey.
In Nov. 2011, I started the following topic about OWC Black Friday discounts and SSD pricing:
viewtopic.php?f=21&t=17318
I eventually purchased the 40GB model, as I discussed in this thread:
viewtopic.php?f=21&t=17322
I also purchased an external 2.5" USB/Firewire enclosure from OWC, anticipating my need to more easily move files to/from the SSD when I was setting it up. Furthermore, I purchased the newest version 3.6 of Intech Hard Disk SpeedTools from OWC, so as to format the drive to get the best performance. We verified the performance benefits of HD Speed Tools in this thread:
viewtopic.php?p=162755#p162755
Sadly, I never could get the OWC Legacy 40GB SSD to work properly in the PB Wallstreet, nor would it work properly in the external enclosure, neither by USB or Firewire, even when I attached it to my Intel iMac. The first and second SSDs I received from OWC worked better with my iMac in the external enclosure than they did inside my Wallstreet, but even then the READs/WRITEs were unreliable and eventually (usually within a day of testing) the drives stopped working altogether.
The third 40GB Legacy SSD I received from OWC (my 2nd RMA drive) did work pretty well. That drive actually worked inside my Wallstreet PDQ computers (I have 2 of them), and I was able to format it with the OS 9.2.1 CD and Apple's Drive Setup. I was also able to install OS 9 from that CD and onto the SSD, which I was not able to do with the first two SSDs OWC sent to me. However, some software acted very strangely. The web browser that came with OS 9 (MSIE 5) worked fine, but Classilla took forever to boot off the SSD and often locked up for 60 seconds at a time when I performed even the most simple operations -- things that never occur on a spinning platter hard drive when used in that same Wallstreet. But even Finder copies were troublesome. If I dragged a folder with a few files of just a few MB in size each over from the OS 9 CD (or another attached hard drive) to the SSD, the first couple files would copy over very quickly, but then the progress dialog would freeze for 30 seconds or longer. Sometimes the copy would complete after a very long time, and other times it keep me waiting for 15 minutes, so I would be forced to restart. Other software would work perfectly. Boot times were fast and reliable, and all the educational software I moved to the SSD for my kids booted right away. But the occasional mystery lockup would occur, and OWC was not able to explain it.
I was upset by the fact I could not format the drive with HD Speed Tools 3.6, nor could those tools "take over" the SSD, despite the fact I could reformat a normal spinning platter drive inside my Wallstreet with HD SpeedTools just fine. I reported this to OWC on multiple occasions, but they never commented about that.
I made numerous HD videos for OWC to show them clearly what I was going through. I am no novice to computing, so I quite nearly overloaded them with details, showing them I was not doing anything wrong. They never did tell me what was wrong with the first two SSDs I got from them, nor were they willing to try a firmware update to get my 2nd and final RMA drive to work in the Wallstreet.
I do not say this to bash OWC. I merely state the facts. OWC Bradley was very helpful through the process, and I appreciate that. But going through the RMA process at OWC takes months, folks. Because I live in Japan, shipping took a long time. Getting a replacement drive from them took no less than 3 weeks to get to me, despite the fact I was required to return my defect drives to them by a deadline. I used EMS at my expense because FedEx (which OWC agreed to pay for) was troublesome for me. (EMS takes about 3 days to get from Japan to the states, and cost about 1/3 of FedEx too.) So the reason this took 4 months to resolve was because of the time required to test, make videos, spend lots of time waiting for discussions on OWC "chat", ship defectives to OWC, then wait weeks to get replacements sent to me, then repeat all previous testing, both inside the Wallstreet and inside the external drive enclosure I purchased. I've always considered myself a man of patience, but this process really put that to a test, let me tell you!
In the end, OWC was unable (and due to the age of the Wallstreets, no doubt, "unwilling") to try a firmware mod to resolve the problem. I verified the problem in two different PB Wallstreet PDQ computers. And that coupled with the fact I have zero issues when using normal 2.5" spinning platter hard drives inside those same Wallstreets proves that my computers were not a problem.
As of today, April 4, 2012, OWC still lists their "Legacy" SSDs as being "For All Laptops that use a 2.5" IDE/ATA Drive." But as my testing has shown that is not true insofar as they do not work with the PB G3 Wallstreet PDQ series (and most likely not the original Wallstreet series either). Furthermore, if you look at the bottom of the individual Legacy SSD web pages, you will see photos of each of the notebook models that OWC says is compatible. As of today, you can still find the Wallstreet series listed, including the PDQ. Again, I must emphasize that this is simply not true as far as the Wallstreet PDQ is concerned. So buyer beware.
I asked OWC several times if they actually did testing in a Wallstreet. Bradley told me indirectly they did, but he never told me directly. He just said that they would never say it was compatible had they not tested it. Perhaps that is what he was told, but my testing proves otherwise. I also spoke to one of the OWC engineers, and he never told me directly if they tested in a Wallstreet. Wallstreets are ancient computers now in 2012, so it makes logical sense that they did not. Had they tested their Legacy drives extensively in the Wallstreet, they no doubt would have found the same problems I found, and then either resolved those problems through a firmware tweak or simply removed the Wallstreet from their compatibility chart. On my 2nd RMA, OWC once again alluded to the fact they tested the RMA drive in a Wallstreet prior to shipping it to me ("alluded" means they did not tell me that flat out nor did they provide me with specifics of that testing). But again, even that drive did not work, and I told OWC that if they did test the SSD in a Wallstreet prior to shipping to me, they certainly did not test it beyond installing OS 9. Because like I said, I could install OS 9 from the CD to the SSD inside the Wallstreet, but then when I booted off the SSD and did even basic things like Finder copies, the problems were very apparent. But again, I think they didn't want to spend a lot of time testing on a Wallstreet (if they did test on one) simply because in their minds, I was probably the lone individual out there still using a Wallstreet. Spending too much time testing would be a waste of time. I am speculating here, of course. But the fact the 2nd RMA drive did not work gives evidence to the fact my speculations may be accurate.
All said, if you own a PB Wallstreet, do not put an OWC Legacy SSD in it. It will not work as expected. And you will lose a lot of money and time during the RMA process. I've been a happy customer of OWC for many, many years, so I do not write this out of some spiteful attack on the company. I don't do things like that, especially when I've been a very satisfied OWC customer until now. I simply wish to report the facts so that future SSD buyers and Wallstreet owners can make an informed purchasing decision. Whether other branded IDE SSDs (if they exist) would work in the Wallstreet is of course something I do not know since I've not tried those. But I will admit to you that I am very skeptical now. I will probably buy things (especially RAM) from OWC again in the future. But as of now, I don't think I would buy an SSD. Perhaps it could be said that their SSDs work better on modern Macs, but the past 4 months discourage me from wanting to test that theory. I hope some of you find this information helpful.
JDW
I just wanted to post a supplementary note (now, two years later) to remark about the quality of OWC SSD's. My PowerBook G3 experience was indeed as bad as you read above. No question. But recently I had need to purchase some computer items from OWC for the office, one item of which was an SSD for our company president's MacBook Pro. Having previous purchased no other SSDs except for the failed Legacy 40GB, I couldn't help but feel some anxiety. But that was put to rest when it was installed. It works flawlessly in the MacBook Pro, and the speed is just stunning. It brought me almost to tears, mainly because it's not nearly as easy to put one in my iMac!
All said, I cannot recommend OWCs "Legacy" SSDs with an IDE/ATA interface in a PowerBook G3; but I certainly do recommend OWC SSDs in modern Macs using a SATA interface.
Best wishes.
antony701
JDW,
Thanks for sharing your experience with us.
Just curious, what SSD did you end up putting in your PowerBook G3?
And would those "Legacy SSD" work on other laptops such as PowerBook G4 or iBook?
JDW
Actually, I ended up never putting any SSD in my PowerBook G3. xx( OWC was the only SSD vendor I found who sold a turnkey SSD solution that had an IDE/ATA Interface. Most SSD's are SATA drives.
So if any of you out there reading this come across a quality, "confirmed and guaranteed to work in a PowerBook G3" SSD with IDE interface, please report back here!
I also would love to find a turnkey SSD solution that has an old 50 pin SCSI-1 or SCSI-2 interface, for use in an SE/30. Yes I am well aware that most people use a CF card solution and hack together a compatible compatible interface. But the best solution is really an all-in-one unit that has the SSDs memory and interface built into the same unit. You also get more longevity and consistent speed with a true SSD, especially those from OWC which have 7% over provisioning.
Vanceone
Hmm.
Is this only for the Wallstreet, or do you think that it affects all of Powerbook line, like the Lombard, the PDQ, and the Pismo as well?
I have a Pismo and I've toyed with getting one of these SSD's for it. I always assumed it would work.
JDW
If you are referring to OWC's "Legacy" line of SSD's that have an IDE/ATA interface, then yes I do believe they may pose a problem in any Mac. The reason I say that is because when I purchased my OWC Legacy SSD, I also purchased an external 2.5 inch hard drive enclosure that can connect to modern Macs by USB or FireWire. When I put the SSD in that enclosure and connected it to my 2009 iMac by USB and by FireWire, I often had problems reading and writing to it. But when I swapped out to the SSD for a regular 2.5 inch spinning platter hard drive, I could read and write perfectly to that hard drive via USB or FireWire, proving that there was nothing wrong with the external enclosure.
Also keep in mind that my bad experience with OWC's Legacy series SSDs wasn't just an unfortunate rare probem with one bad SSD. I went through three of those Legacy SSDs, and all of them exhibited the same problem. I think this gives strong evidence to the fact that OWC had some serious problems in their IDE interface for that line of drives. Whether they have rectified that problem in their "Legacy" line of SSDs over the past year is not something I cannot comment upon. All I can say is that their SATA line of SSDs works perfectly in modern MacBook Pros. But such is not too surprising in light of the fact that the IDE/ATA interface is very different from the SATA interface.
beachycove
In OS9, a simple CF card on an IDE-CF adapter works just fine for most purposes. It will also work in OSX, but there would be the trouble of finding a cheap/large enough CF card to make it worthwhile. In OS9, an 8 GB card is plenty.
JDW
Believe me, I've long known about the CF card solutions for vintage Macs. I researched quite a lot about them, in fact. I also kept a close eye on the dialogue here in this forum about ARTMIX Japan's CF card solution for the SE/30. But I had good reasons to purchase a turnkey solution (or at least, what I thought would be one) from OWC.
First, we all know that flash memory has a much more limited life compared to spinning platter hard drives. As such, OWC's 7% over provisioning is a definite plus over any CF card drive solution. OWC also advertises that there SSDs don't slow down over time like other flash memory solutions, and especially not like a CF card would. Defenders of CF cards will of course argue with me about this saying, "in the greater scheme of things those differences are marginal at best, and really don't matter that much." But to me, it matters.
The other reason I chose an OWC SSD, above and beyond their companies great reputation for quality SSD products, is the fact their 2.5 inch Legacy SSD drives are a drop in solution for old PowerBooks that don't require any mounting adapters or special add-on interfaces. Again, for some of you, that is meaningless and irrelevant. But for me, it has a lot of significance.
Yet another reason I chose OWC's Legacy SSD for my PowerBook G3 Wall Street was because I thought it would be faster overall than any CF card solution. And truly, if CF cards or SD cards were in fact faster, why then are true SSD drives selling so well? Why aren't more people just foregoing those drives and sticking an SD card in the side of their iMac and using that? Now some of you will try to argue that a true SSD drive is faster in "modern" Macs than a CF card or SD card, and that old vintage Macs have such slow drive interfaces that really doesn't matter which one you put into them. But in my opinion, such arguments are indeed true when it comes to a Macintosh Plus computer from 1987, but consider well that the word "vintage" covers a broad spectrum of Macs that were produced over many many years. As such, the interface in a Mac from the 80s is very different from the Mac in the later 90s, which also is very different from Macs in the 2000s.
Even if you don't accept any of my arguments, the fact is that others here in various threads have posted their benchmark results from CF card solutions in various old Macs. So I want to purchase an OWC SSD so I could run benchmarks on it and then publish my results for everyone to see once and for all which is faster (in a PowerBook G3 Wallstreet II, anyway). Sadly, OWC screwed up royally on their IDE interface for their Legacy SSDs, and as a result I never could get it to work so that I could run benchmarks on it. That part still dsappoints and disgusts me.
And so, I still have my two PowerBook WallStreet computers, but neither one of them have an SSD in them. But should one of you out there ever come across a true SSD 2.5 inch drives that works perfectly in an old PowerBook G3, be sure to post back here and let us know!
