Output A/UX system console to serial port
robin-fo
Hi everyone,
I can log into an A/UX machine using the serial port. However, this only works when the system is fully booted. Is there any chance to read console messages during startup?
robin-fo
Brilliant! Although I expected a bit more output... (It's still not the same as if you would press the "messages" button during startup)
zefrenchtoon
My goal is to find out where a Performa 475 crashes during boot 🙂
Very interesting !! I will follow you quest ! :love:
I've read that the main problem is the lack of support of the 475 "graphic card". I thought about trying to get the linux driver to adapt it to A/UX ... but I'm sure that it is a silly idea and I do not have enough skills to do that o_O
I had a look last night and there *is* serial console output code in the kernel for early boot. How to turn it on and whether it actually works is another matter...
Ooh, that would be useful to know.
I've also heard that. But having spent a little while digging around in the video section of the A/UX kernel for my VNC project, that seems a bit of an odd statement: there really aren't any video drivers in the A/UX kernel, it loads the Mac drivers out of the declrom and then does hairy things to make them work. So I think the story may be a little more subtle.
robin-fo
Actually, I‘d expect to be able to enable the serial console in the bootloader (as in Linux?), but I didn‘t find any hint in the official documentation…
There seems to be a variable in the kernel which seems to control whether the output is sent to the serial port or not. It's set to 0 by default...
ed: it's not the variable I thought it was, it's a different one. I can't read :)
OK, this was a bit harder than I expected, but here, have a dodgy as all hell kernel module/patch that forces early boot output to go to serial (tar file attached to this post). You'll still need to do the syscon swap I mentioned above for later-stage boot messages.
The file attached is a .tar.zip, which is a bit silly, but is only to get around the fact that the forum won't let me upload a raw tar file. Just unzip it before transferring it over to the A/UX machine.
First of all, make sure that A/UX startup is set to verbose default boot (under Preferences -> Booting...) add '-v' to the launch command).
Then, to install, untar it, then
Code:
# cd kernel
# ./install.sh
# newconfig se
Assuming newconfig doesn't scream at you, then you should be able to reboot and get early output on the serial port. Note that those messages will no longer appear on the video console, because it's late and I'm tired and I can't be bothered to work out how to make it work on both.
  • se.tar.zip
Now that I'm awake, how this works: I started by looking at the kernel's printf to see how it actually did the output. It calls a function called 'outchar' for each character, which calls two other functions, the first of which stuffs the character in the kernel buffer, the second of which—if verbose mode is enabled—actually does the output.
The output is done by calling through a global function pointer called locputchar. By default, this is wired into serial output. But when the video console mode driver loads (in the very early init phase), if any video devices exist, it swaps that over to the video console.
This module, following the traditional MacOS development practice of "finding other people's global data and messing around with it without permission", loads in early init (the pf flag in its master configuration file) after the console driver loads, and puts the serial output putchar back again, undoing the change.
Does this mean you get full serial output if you unplug the monitor?
If I'm reading the code correctly, yes, so long as the video card in question is doing the right thing. But please bear in mind I'm reading disassembled/decompiled code I don't fully understand, so this has a big asterisk after it.
Yeah, not all cards report back "no monitor connected", but many do. Interesting.
Probably clashes with VNC objectives - not sure what the framebuffer does with no monitor. My 6500 seems to refuse to boot with no monitor attached.
robin-fo
Ok I tested it on the 475 and it appears to crash before there is any console output if I observed correctly...
