GondolinOnMyMind
All,
Based on instructions on https://github.com/unxmaal/aux_sdcard I downloaded the image and copied that onto a sd card. That went well. The issue arises when the os is booting and ”A/UX Startup” is being run. I include messages both as pics and as text for search engines.
First error message is:
If Continue is clicked then a sencond message is presented:
The shell starts but errors are printed to stdout
Now prompt is presented but any and all commands are unknown.
The computer I’m running this at, is a Quadra 700, 68 MB ram and with a bluescsi.
Anybody got an idea what is going on?
This has options to Continue or Exit.”Initialization. Error. Standalone program space is too small (=65660740). The shell needs to run in a particular area of memory. Either you are trying to run under a memory sharing System or the System heap is too big”
Now the only option is to click Continue.”Initialization. Warning. Standalone program space may be too small (=2048). The shell needs to run in a particular area of memory. Either you are trying to run under a memory sharing System or the System heap is too big”
autorecovery
Couldn’t run fsck
chroot
_set tz
Couln’t execute _set tz
chdir
autolaunch
Couldn’t execute launch
