Official Paint Color of Mac 128/512/Plus?
Admiral Ackbar
What is the official color code (is that a Pantone number?) of the Mac 128/512k/Plus? Looking to 3D print a case/holder that will sit next to the Mac, and want the colors to match. I have seen it called "beige" and "putty" but wondering about the specific code for realistic match.
Or is there something known to be very similar like something from Lowes?
Thanks for all ideas!
olePigeon
Pantone 453 is "Apple Beige," but keep in mind that age and exposure to sunlight will mean it's unlikely to match these days. You'll probably want to use 453 C because the plastic probably won't absorb any paint.
If you want a cheap, pre-mixed house brand paint you can pick up at the local hardware store, "Heavy Hammock" is exceptionally close.
Admiral Ackbar
Wow, Mr. Pigeon. That is great info. Thanks! I am looking to 3d print or otherwise find a box/case to put next to the Mac to hold Floppy Emu and Raspberry Pi, want it to all look matching. Much appreciated.
dochilli
Ok, one correction. I think it was RAL 1000 that I used. Next week I could take a look at the can and tell you exactly.
unCoopervised
New member
New here - just saw this. I'm going to try Krylon Fusion in "Clamshell" beige. It's about number 8 on my to-do list so it may be a while but I'll post a pic either way. I considered retro-bright but I live in a small condo and don't have a space to do that. Also the Mac SE/30 I have is very worn and has what looks like black sharpie smears, so retro-bright wouldn't fix that. I've used Krylon Fusion in the past on both metal and plastic and it bonds very well. . Here's the color:
