uniserver
http://web.archive.org/web/20040803184138/http://gabezing.sytes.net/475clockup33Mhz.html
i followed this old article from applefritter,
and it really is this simple, the oc is worth it, you can really tell!
also to go one extra step , i'v installed the full 040 as well, with thin heat sinks.
This is so easy its crazy not to do it.
(unless you are trying to keep your machine stock)
i made the following image.
