beachycove
Having had my main 50-pin drive fail in my 840av, I have been doing some work on it today to get it back up and running. I installed in it, along with a 1GB boot drive, a SCSI Jackhammer card and a 9GB IBM 68-pin SCSI drive. The machine is running 8.1 for HFS+, and has FWB Toolkit v. 3 installed, along with the standard Jackhammer software. Termination etc. are all done right. It should work.
The trouble is that one necessary feature does not work: the machine will not shut down. If the Jackhammer is disabled on startup (CMD-OPT-J), or the card removed, the machine does shut down just fine. If the machine starts up normally, by contrast, both the Shut Down and Restart menu commands just make the machine stop dead in its tracks. I can hear the drive heads move (parking?), and the mouse pointer will still move on the screen, so that the machine is not frozen, but it is as if the final step of actually shutting off power cannot be reached. I can move the pointer, but I cannot click on anything, so in fact I have to press the power button on the front to make the machine turn off.
Any suggestions? I am lost, as in 20 years of using Macs this one is new to me.
