NeXT Development Board
Gorgonops
Moderator
Staff member
maybe they made this, so the NeXT could to talk to their CNC machines?
Again, the only way the NeXT would be able to talk to it/through it is if it were jumpered to some other external port. There's absolutely nothing connected to the NuBus connector. (Except possibly the 5v and ground rails.) I am curious where that snipped off cable lead went to; I'm having trouble following the wires but it looks to me like the wires terminated on the input pins of one of the shift registers. Perhaps the other end of that wire "snooped" on something on the NeXT's motherboard and the shift register was used to capture some number of transitions (IE, the board acts like a crude logic analyzer) which allows the data to be read off to some external device via the connectors on the back. (Or, again, this board was being used for something completely off-the-wall unrelated.) I suppose the OP could try translating it into a schematic if so inclined.
genie_mac
Weird indeed...There's a couple of dip switches as parallel input to the circuit (the 25 pin connector seems to be used as a ground for the switches!) which are then serially shifted into loads of logic gates, flop-flops, inverters etc and the shifted back into an 8 bit parallel output which is fed to the LEDs.
Somehow to me this looks like someone has used this board to prototype some circuit (possible some state machine?) with switches as inputs and LEDs as outputs. But why are there some connections to external connectors on the back? Was the circuit possible simulating some device that would later be connected to serial port / ADB etc? Seems the output also goes through the RS422 line driver to the connector besides the push button. Is this a 8pin serial port?
Would someone be willing to reverse engineering this and build it in Pspice? :lol:
techknight
What i think? someone just had one of those boards laying around as spare and just used it to prototype a circuit instead of running out to ratshack and buying one.
Thats my thought.
Trash80toHP_Mini
NIGHT STALKER
Ditto, but CrapShack never sold perfboard with offset thru-holes for four D-Shell connectors. Did they sell them with any on board?
I don't remember anything like that being available from Jameco or anywhere else back in the wire-wrap day either. That's a very :cool: ProtoBoard without the NeXT connection, which wasn't worth much for very long even when that section was worth anything at all.
Gorgonops
Moderator
Staff member
I've seen some pretty huge generic protoboards with edge-rails for connectors like that before, but I also second the notion that this may well have been a case of someone just happening to have this thing handy and using it to prototype some random thing that has nothing to do with NeXT. The only thing about it that at all suggests to me that *maybe* the board was intended to be seated into a NeXT chassis while running is I didn't see in my cursory glance at it an obvious place where they would have hooked up an external power supply and they were apparently using the "5v" and "ground" rails as labeled... which means it *could* have depended on the 5v rail coming through the NuBus slot connector to power it. But there may well be a wire to, say, one of those 9 pin connectors that provided the power feed, or something else that was snipped off.
(This was probably a very expensive board back in the day, certainly by protoboard standards. It's looks like it's multi-layer; the only thing the multi-layer-edness seems to be used for outside of the unpopulated NuBus connector section is for the power/ground rails, but that alone is pretty fancy.)
CelGen
The NeXTBus dev board was nothing special at all. It was just a breadboard PCB with grounds and power traces added. The holes at the back for ports were for the end user since you can't buy connectors that plug into the grid conventional pattern. It looks a lot like someone started work on something but then gave up. Components are missing but the board shows no signs that they were desoldered.
I have NeXT's description of the board alongside a photo in their 1990 Products catalog. They were trying extremely hard to get vendors to build NeXTBus peripherals but even at $350 for the NBIC, full documentation and the board they didn't sell a lot of them (which sucks because they were literally telling people to go wild with the hardware).
What IS however special is the NBIC chip that linked your prototyping to the NeXTBus. It's missing from this board. Again, doesn't look like it was ever installed.
Without it, that was just one VERY expensive square circuit board with a NeXT logo. I hope the buyer knows that the board is neither all that valueable or useable.
Edited: It seems the catalog photo shows a board with a different layout where all the rear connectors are just what you would of expected on the older 030 cube boards (DSP, Serial, SCSI, Printer, Ethernet, Monitor).
