NetBSD 4.0 software
ChristTrekker
Anticipating that 68k binaries will be long in coming, I've started building my own again. I threw out all my old 1.6 and 2.1 binaries and started over from scratch. Grab them if you're interested. If you have any special requests, post them in this thread - no promises though.
ChristTrekker
Thanks for this - may have to try NetBSD again!
If so, check the recent archives of the port-mac68k list. A fellow named John Klos built 68040-optimized versions of the entire base system. That's what I'm running on my Q840. That said, the package binaries I build do not have any particular optimization so they should work on any 68k NetBSD.
QuadSix50
Good to know. Thanks for the heads up. :cool:
MrCoffee
Very Cool.... have ta try this out on my SE/30...
Your running on a Q840AV? I thought NetBSD had issues with the 840...?
ChristTrekker
SCSI is slow on the AV machines (slow enough that I may put /usr/pkgsrc on NFS to get a speedup!), but other than that it's dependable. I acquired the 840 before I realized that issue; now I wish it were a 800.
lupsyn
Thx so much!
paws
Eh, i'm trying to install pkgsrc on my Quadra 700. I just threw the tar.gz at the MacBSD Installer program, and it looks like it'll take some 30 hours to unwrap it - does that sound right?
ChristTrekker
Boot into NetBSD and just use tar -xvzf on it. Heck, unpack it elsewhere and suck it across your LAN, even that would be faster.
paws
Yeah, found that out. Tried untarring it inside NetBSD - I ran out of disk space quite quickly, though. Don't you suppose you know how much space it's supposed to take up?
porter
The contents of an unzipped tar.Z or tar.gz takes (give or take) the same size as the uncompressed/gunzipped tar file itself.
There are other alternatives such as
(a) put tgz files on a CD
( B) put tgz files on anther disk
© read tgz files through ssh from another machine
(d) read tgz files from a nfs volume
ChristTrekker
As to special request - pretty much anything MIDI and audio related :D
Fixed URL. Is there a specific package you cannot find in the official pkgsrc binaries? A bulk build was done for m68k recently so there's not as much incentive now unless there are specific needs.
You probably want a 1GB disk to be able to have space for it and still do anything else.
paws
Yeah, it's going on an external IDE disk with a ->SCSI converter... Might even speed things up a little...
