Need help IDing card.
crazyben
Can you help me identify this card. Is it emachine video card?
chelseayr
a video card won't have that unusual black port on the back plate, I'm really guessing this is some sort of network card specifically for aui&ethernet (not able to see what the black port is really shaped as to be certain) .. as for the many identical chips around one of the two large chips mm that seem to be the norm on certain nubus network cards anyhow as this one other example shows: https://149564388.v2.pressablecdn.com/wp-content/uploads/nubus-net6.jpg
It's an eMachines video card. They made combined video and ethernet cards, on some the ethernet was only available with an optional daughter card, this is one of those cards without the option.
So, just a video card. Should have accelerated graphics. My experience with eMachines cards is that the specs are quite good, they tend to do millions of colours and be accelerated, but the drivers are a little flakey.
If it's cheap, jump on it, if it is... A more than a Radius PrecisionColor XK, get the PrecisionColor instead.
crazyben
Thank you. I already have it. Got it lot in with other cards pretty cheap.
crazyben
Which Mac do you recommend I use this in? Iifx?
chelseayr
@cheesestraws mm good thing I guessed rather than saying that it was actually so. I mean I looked up how much pins aui had and it somehow corresponded .. didn't know about regarding cable attachment differences
interesting combo card, then again i've heard of other kind of interesting combos on non-mac's such as fastethernet&scsi for sun or all sort of old and new pci things on the windows pcs side
Yup - this is why Apple used AAUI not AUI, because you can easily plug a monitor into an AUI socket and vice versa, and bad things would probably happen. The plugs are physically the same, it's just that AUI uses a sliding latch not a screw for some reason. This is abstruse trivia and I wouldn't blame anyone for not knowing it. :)
