I recently acquired two Mac 512k with the original 400k floppy drives.
One of the machines had a jammed floppy drive so I did some searching and learned how to remove the crusty grease and lubricate the eject mechanism.
I have the eject mechanism moving freely, but I am unable to boot the machine from system 2.0 or 3.2 disks imaged onto 800k floppies.
I created images from multiple machines.
I even removed the 400k drive and put it in my plus to see if it would work in that machine.
It doesn't, I can not even format a disk.
I have the 400k in the plus, and boot the plus with system 2.0 in an 800k external.
I did clean the read head with a q tip and alcohol.
I also attempted to remove as much of the grease as possible from the ball screw that slides the read head.
I did not adjust any of the screws for head alignment or head height. Although this page suggests raising the read head:
http://lowendmac.com/tech/after.html
I read a few posts that also suggest demagnatizing the read head, but I haven't found a procedure or tried it.
What should I try next to get this drive working?
I am making some assumptions that may be false. First being that a Plus can use an internally connected 400k floppy, next that I didn't totally screw up the head alignment by cleaning the ball screw. I did move the ball screw manually before I thought about it being a bad idea.
The other 512 doesn't read either but I haven't attempted taking it apart yet.
