My SE/30 Lives!
tanaquil
Thank you Uniserver! My baby SE/30 is now up and running with a freshly cleaned and recapped board, perfect sound, 68 MB of RAM and Ethernet.
The short version: everything works great, and I can't wait to play more with it. Next item in the budget is a SCSI2SD to replace the (working) 40 MB hard drive.
The long version (or, why this took me six hours yesterday):
The SE/30 was working when I pulled it from the basement (miracles!), but after going through all the pain of taking it apart to remove the old battery and check the board, I could see it had leaky caps, and I wanted to have a nice clean re-capped board before I went through the pain of reassembly. (Little did I know that I would end up taking it apart and reassembling it at least a dozen times.)
I sent it off to Uniserver, who did a ton of work not only recapping the board but tracking down the source of a bad startup chime that I hadn't even noticed (that saga is elsewhere on the boards). The board came back in beautiful shape, but I had to wait to put it all together until I could save up a little money for the extra RAM and ethernet I wanted to add.
I watched ebay for a while to see if a SE/30 ethernet card would come up, but the only ones I saw were going for hundreds of dollars (someone is trying to sell one right now for about $420, yeesh, good luck with that). Eventually, I realized that I actually had the card I wanted (the one that consists of two cards with a small cable running between them), installed in my working IIsi. I use the ethernet on that machine all the time to transfer files, though, so I had to find a replacement card for the IIsi.
Compared to the SE/30, finding ethernet for the IIsi is easy, because there's much more room to work inside the case of a IIsi. I ended up getting a riser card (+ FPU, bonus!) in a sort of metal cage, and a nubus ethernet card to plug into it. Fits nicely in the IIsi and works like a charm, and now I have an FPU in the IIsi to boot. That part of the project went quickly.
Next was installing the new RAM from OWC (4 X 16) into the SE/30. Many people on that site and on these boards had reported having no problem getting that RAM to work in an SE/30, so I thought it would work, but I kept getting a sad mac chime. In the end the only configuration that worked (after many, many reassemblies) was putting the original 4 x 1mb RAM in bank A and putting the new, larger RAM in bank B. Weird, but hey, whatever works. Once I finally got a working configuration, I wasn't about to try any other variations. Anyone else had luck with just installing 4 x 16 in bank A and nothing in bank B? That was the first thing I tried, but it never worked for me.
Meanwhile, I was diagnosing all this with no video, because even after I started getting a happy startup chime, I couldn't see anything on the screen. I could hear the hard drive starting up and see the little hard drive indicator light on the front of the machine, and floppy disks seemed to make happy reading sounds when I inserted them and/or started up with them, but the video was black. Turning the brightness knob didn't help.
I must have uninstalled and reinstalled every card and cable a dozen times, trying to find a combination that might cause the video screen to light up - nothing.
Knowing Uniserver, I was sure the problem had to be with my analog board and not chips on the circuit board, but the video was working when I originally pulled the motherboard, and I couldn't figure out what I had done to break it.
I tried putting the SE/30 board in my spare SE, and sure enough, the screen lit up and the computer started normally (well, with a floppy, the hard disk in my spare SE doesn't work). So I was just contemplating the horror of having to completely swap out the analog board, CRT and power supply in my SE/30, when I noticed that the thingy that connects to the yoke of the CRT (technical term? it looks like a square of cardboard with wires) looked different on my SE than it did on the SE/30. The one on the SE/30 was loose and wiggled around.
When I pushed it on tight, everything started up and worked perfectly. Six hours of work because I somehow knocked a square of cardboard loose and didn't know enough to plug it back in!
(I'm amazed I never broke the neck of the yoke. There was so much tugging and swearing. I hate the cable that runs from the analog board and plugs into the motherboard SO MUCH, who invented that little clamp on the side, it's a torture device.)
While I had the cover off and the unit working, I adjusted all the video controls except the width. I don't have a proper TV tuner tool, and none of the makeshift tools I was using instead would turn that stubborn width coil reliably. Can anyone recommend a brand/make of tool that works well with the width adjustment? I'm looking at several different ones on Amazon. Right now the screen looks ok, but it's definitely too wide.
So anyway! Any applications recommended to really show off the speed/power of the SE/30? I have System 7.1 on it now, and the control panel/extension that allows you to turn 32 bit addressing on, so all the RAM is showing up. I used to have a Classic 4/40 (still hanging out somewhere in the basement), and I'm curious to see how the machines compare.
Elfen
Congrats first of all! And double congrats on figuring out the minor problems you had!
The Classic would be more in tune with the SE as they share the same 68K CPU. The SE\30 would be a lot faster than either one. The good thing is with the Classic, you can turn it on and boot its ROM Disk by holding down Option-Apple-X-O when you turn it on. It will boot with System 6.08 which you can use to copy onto floppies and then use the floppies to install System 6.08 on the SE or SE\30. This is great for Data Recovery.
Radio Shack has the correct tool in their "TV Tuner Plastic Tools" set for the width coil. You can order it online, its usually under $10.
Applications? It depends on what you want to do with it. The BASICs would be nice - Office software like MS Works or Claris/Apple Works; Internet tools like Netscape and Eudora Email; a few games and some Desktop Publishing Programs. A few simple tools like be nice too, like JPeg Viewer which helps certain programs (like Netscape) to display JPEG Pictures.
olePigeon
7.1 Pro is the best. :)
As a side note, an alternative to ethernet would be an AppleTalk to Ethernet bridge (one that supports MacIP.)  That way you can get all your vintage Macs onto your ethernet network with a single device (well, up to 8 of them, anyway.)
mc9625
I'm trying to find a network card for the SE/30 but I guess if it is worth the extra money to surf the web. I currently still have only 4mb of Ram (other 4 are on their journey from USA and should arrive this week). I'm afraid that at the very end it will turn out to be so painfully slow to make the network card totally useless. I plan to make very little web surf anyway, just for fun anyway.
Did you try to surf with the SE/30 yet?
tanaquil
I haven't tried the internet yet - I was just so relieved to have it up and working, and was concentrating on getting it to the point where I could see all the RAM. TattleTale sees the internet card, so I assume it should work once I install all the necessary drivers and network support software.
I usually don't try to surf the web on my 68K machines; what I really like having ethernet for is fast file transfer to and from my other computers, especially my modern MacBook that is acting as an FTP server. I do occasionally surf on my OS 9 machine, and sites just look so clunky or don't work at all (using Classilla).
Good luck with that network card search! I wish I could find a SCSI-to-ethernet adapter for less than $200.
SE30_Neal
I have networked it up as mine came with a 10 base network card, 2 issues; 1 need more ram as mentioned above also i cant see my mac mini on the network as osx 10.7 isnt backwards compatible that far. Im waiting for a powerbook (pb)1400 which I've ordered to use as a bridge machine which has os 9 on it so in theory can see both machines and allow a shared drive so i can load it with software as the 40mb hdd is limited to 5-6 programs.
Other issues as i've wanted email on the se/30 but the old email client software i have doesnt accept SSL so i cant run email directly from the se/30 so it looks like ill have to run my mac mini as an email and internet server and link it to the se/30 via the bridge pb 1400 to make all that happen, then finally i should be able to build up a good software library or copy to floppys
TimHD
With Fetch 3.0 (Ftp software) and a 10/100 hub + SE/30 networking card to connect you to your home network, you can get software from a number of FTP sites that still hold huge libraries of Mac OS software without the need to use Netscape etc.
Eg ftp://ftp.iinet.net.au/pub/macintosh-centro/
NB: I've also managed to connect via ftp to my Mac using its IP address and access shared folders, if you prefer downloading using the PowerBook or Mac Mini.
SE30_Neal
Hi Tim, I have thought of ftp but have no experience of it so thought the pb would work well as a test bed to work out old mac networking (as i dont know settings etc, do i need to asign each machine with its own ip? if i can get them to see each thats kind of stage 1, I've only ever networked a few pc's before. My ultimate goal is to use my nas drive as the library as it's 4tb so thought a shared folder on that would be ideal. Should i attemp to set up ftp to that?
tanaquil
For some reason, on my IIsi (SE/30 not tested yet), Transmit won't see my modern Mac as an FTP server but Fetch will. Fetch works great. All you have to do is enter the IP address of the modern mac into Fetch.
The only slightly tricky thing might be activating the FTP serving capability of your modern mac - I used some software to do it, I think it was ftpd-enable. I believe it can also be done from the Terminal.
This might be obvious, but note that FTP might not preserve resource forks (unlike direct file transfer from one mac to another), so I always stuff everything to be safe before ftp'ing. Usually it comes stuffed already from whatever online source I got it from. My NAS (where I store some big files) definitely isn't resource fork safe, it is linux-based.
Elfen
Try setting FTP to send the file as a Binary file; sounds to me it might be sending it as a text file.
Get "Utility Dog" as well. If you know the Resource bytes of the file (first 8 bytes), you can restore them by changing the File & Creator ID info.
