MacDan
Hey guys, yet another question. This one one is about my Lombard.
****LOOK DOWN THE PAGE!! PLEASE!
After installing both OS 10.2 and 10.3 (from retail disks), my Lombard would act normally and work perfectly. I should mention now that the discs are fine. They work on other computers. Once I shut it down, the problem starts. I believe that the Hard drive won't "hold" the OS for more than a few hours. I can shut it down and come back an hour later and it'll still be there. Not after 4 hours, though. I've tried it all to fix the problem, except this:
"Some Lombards have problems with OS X if there is RAM in the top slot. Try removing the RAM module in the top slot during installation. It would be nice if you had a 256 MB module in the bottom. Make sure that larger module is in the bottom slot and leave the top slot empty and try the installation. Hopefully you have enough RAM to do that.
Think this'll work? Is this Lombard a lost cause? Is it the hard drive (it's an IBM travelstar 20GB)?
The Lombard: 400Mhz, 20GB HD, 192 MB RAM.
