Also note, the video circuit in the SE/30 will run all by itself regardless of what the BUS is doing... period. It will draw on the screen, the default state of the VRAM. Different brands of VRAM draw different initial patterns. Simasimac is created by only 1 type of RAM, while zebra stripes are created by a different brand of RAM. NEC vs TI. I think.
So, if you get black screen, the video circuit is bad and needs troubleshooting. in my EXPERIENCE, the #1 cause was the VRAM itself. Second to the PALs. if the PALs are bad, it will prevent the machine from booting as well, especially if its holding up the BUS which could also cause no video, as they are also used at refreshing the screen with whatever contents are in VRAM.
there 5 PALs. Find the one that is common to the video generation, and also attaches to some control lines on the main data bus. That would be where I would start.
