Macintosh Plus screeching sound
bibilit
I have a Macintosh making a screeching sound, but working ok otherwise.
The issue is in the LB (tested with another and working ok, so the AB is fine)
i have done a swap on both ROMs and those are ok, have not been any further, but probably a chip bad on the LB.
How is generated sound on the Plus ? (any particular chip ?)
joshc
See attached Apple's schematics for the Plus (they are bad scans, so a bit rough).
Looks like sound is shown on page 3, here:
bibilit
Thanks, yes i was able to find that same picture, but the quality was poor and i was unable to see much. should have a look at my board, probably not a chip freely available.
joshc
It looks like a Sony sound chip with an Apple part number, from what I can tell on this pic (couldn't find a high res enough pic and don't have a Plus logicboard to check myself).
Is the sound chip part of the reset circuit on the Plus? On the Mac II at least the sound chip is used to reset other hardware. If this is the case on the Plus, then that hopefully means the sound chip itself is likely working.
Yup, the reset switch is connected to the Plus sound chip and the rest of the computer is reset from there. So the chip is doing some or all of its job at least.
bibilit
Yes i agree, the Plus is working except for the noise, so probably the chip is half working.
That Plus had a lot of issues ( the AB board had several issues, bad transistor, bad diode bridge, burnt resistors...still not working though) LB had a bad ram and that noise issue, missing mouse rubber ball... but was not too expensive either.
I'd start by beeping out pins 2,3,4 (to the 6522) and 16 (to U4D and onwards?).
techknight
nothing obvious, i will remove the chip and solder a CI support first.
Grab a scope and check for oscillation. That sound IC looks like an amplifier, etc. the sound is generated elsewhere as indicated by the sound input pin. Check the output, AND the input for oscillation/noise.
bibilit
So managed to remove the old Chip, and test with another unit (had no other Plus at hand but a bunch of bombed SE/30s, and reference is very close... moreover the SE/30 had two of them)
Didn't worked, and can't use the switch to try a reset (the Plus suffered from a battery leak as well, both switches are corroded) so i will go ahead @techknight and follow your advise
