I recently acquired a Macintosh Plus (version with the international 220V analog board - as I am in UK).
It seems to be working fine. However, there is a strange issue with it.
When switched off and connected to a wall socket (the switch on the back is off) it always after a couple of minutes keeps tripping RCD fuse in my house. So it looks like it is leaking current to ground somewhere.
It is not the power cable. I tried to visually inspect the analog board, measure input voltage and ground using a multimeter and did not find anything suspicious or obviously broken.
Any ideas?
Any ideas?
