Okay.
There you go. Blown
RIFA filter capacitor. Interestingly enough only "international" boards have this cap. It's hard to find the info on the web since most Macs were sold in the US. If I had my Mac Plus on hand I could give you that information...but I can't do that now. Not until two weeks time.
Maybe you can still read what's on the blown cap, I think it is the same one as his little brother sitting next to him.
Once we know that, you can order the part on digikey (or the NZ equivalent, apparently you live in NZ right?) and then you have to find someone to desolder the dead one and replace it with the new one.
About that diode, it "looks" okay. Once you go higher the expected voltage the diode burns out and needs to be replaced. You picture shows that it was once hot in there. But not hot "enough" to kill it I think. But you should definitely check it with a multimeter, here is the
specs of that diode. You can find information on how to test a diode on the web pretty easily. As for replacement, as this part was discontinued some time ago, this is the correct
replacement as discussed on this
thread
Good luck finding someone to do the job. When I introduced my SE/30 to a workshop in Paris, France, the guy thought I was still using it daily and suggested replacing it for a newer one. LOL
