There is a via (a through-hole) right next to the pad which is where the pad connects to the Ground Plane.
You could either solder a wire into that hole and connect the other end to the capacitor terminal, or scrape the green coating off the trace that you can see between that hole and the capacitor pad. Under the green coating is copper. But don't scrape so hard that you cut through the underlying copper.
To solder a wire in that hole, you really ought to remove the old solder in the hole, which can be very challenging. You would need to add solder flux to the hole first, to help the old solder melt and flow properly and then use some good quality desoldering braid, like Chemtronics. Do not bore the soldering pencil into the hole, if you are having difficulty. The hole has a relatively delicate copper coating (put there by electroplating) and can be damaged by mechanical insult.
