Macintosh Color Classic Disk help
24Pintech
Hello, I was having many problems trying to get my SCSI2SD working on my original Macintosh Color Classic but I decided to follow this forum (https://www.savagetaylor.com/2018/0...lassic-68k-macintosh-using-a-scsi2sd-adapter/) exactly and I got booted into the OS but I got an error code saying "Disk initialization failed because the disk is locked" Can somebody help me? I am not sure as what to do next and when I look up the error code it doesn't bring up anything similar to mine it's just the New apple support that shows up. Please help thank you.
ymk
Is your floppy drive working?
24Pintech
Unfortunately not, I was able to boot into OS 7.5.3 with the SCSI2SD but after It starts to "repair" it brings up "Disk initialization failed because the disk is locked" I will provide pictures in a little bit. I forgot to add that this is a project in my computer classroom for our Macintosh Museum. so I will provide pictures within 2-3 hours of this post right after school unless I can access internet on my phone then it will be earlier.
24Pintech
ymk
The problem is related to the floppy drive, so you can either attach one or do the resistor fix I linked.
ironborn65
To close the thread, I had the same issue, in my case the floppy drive was the culprit, I solved it by replacing the it.
